[mapguide-internals] Individual Contributor License Agreement andSpanish Localization
Tom Fukushima tom.fukushima at autodesk.com
Tue Mar 20 11:12:59 EDT 2007
Hi Jorge,
I won't be able to get anyone to look at it this week; however, someone
may be able to start on it next week.
What they will be doing is a search through the code for occurrences of
the Exception or ErrorDescription name and looking at the method that it
occurs in.  For example, I just did a search on
"MgCoordinateSystemMeasureFailedException" and found that it could be
raised from the following methods:
///<summary>
/// Measures the euclidian distance between two coordinates.
///</summary>
///<param name="coord1">
/// An MgCoordinate that defines the starting coordinate.
///</param>
///<param name="coord2">
/// An MgCoordinate that defines the ending coordinate.
///</param>
///<returns>
/// The euclidean distance from coord1 to coord2 in coordinate system
units.
///</returns>
double MgCoordinateSystem::MeasureEuclideanDistance(MgCoordinate*
coord1, MgCoordinate* coord2)
///<summary>
/// Measures the distance between two coordinates.
/// This function uses the coordinate systems ellipsoid
/// definition and a great circle algorithm to produce the result.
///</summary>
///</param>
///</param>
///<returns>
/// The great circle distance from coord1 to coord2 in coordinate system
units.
///</returns>
double MgCoordinateSystem::MeasureGreatCircleDistance(MgCoordinate*
///<summary>
/// Computes the distance between two coordinates.
///</summary>
/// An MgCoordinate that specifies the first coordinate.
///</param>
/// An MgCoordinate that specifies the second coordinate.
///</param>
///<returns>
/// The distance between coord1 and coord2 as a double in coordinate
system units.
///</returns>
double MgCoordinateSystemMeasure::GetDistance(MgCoordinate* coord1,
Is the above what you are looking for?
Thanks
Tom
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jorge
Rubio
Sent: Monday, March 19, 2007 1:21 PM
To: MapGuide Internals Mail List
Subject: [mapguide-internals] Individual Contributor License Agreement
Hi friends
I sent a signed Individual Contributor License Agreement by fax as was
suggested when I sent the first e-mail offering spanish localization.
In order to do an accurate translation to spanish I need more info about
what the following exceptions and error description mean and when they
are achieved.
When I finish translation, files will uploaded following Tom
instructions.
[Exceptions]
MgCoordinateSystemMeasureFailedException              = The coordinate
system measure failed.
MgDwfSectionNotFoundException                         = The specified
section was not found: %1
MgDwfSectionResourceNotFoundException                 = The specified
section resource was not found: %1
MgEmptyFeatureSetException                            = The feature set
is
empty.
MgEndOfStreamException                                = End of stream
exception.
MgFeatureServiceException                             = Feature Service
exception - %1
MgInvalidCastException                                = Invalid cast.
MgInvalidDwfSectionException                          = Invalid DWF
section:
%1
MgInvalidFeatureSourceException                       = Feature Source -
%1
MgInvalidLogEntryException                            = An invalid log
entry
was found.
MgInvalidOperationVersionException                    = The requested
operation version is invalid.
MgInvalidResourcePreProcessingTypeException           = Invalid resource
pre-processing type.
MgInvalidStreamHeaderException                        = Invalid stream
header exception.
MgLengthException                                     = A length
exception
occurred.
MgLogicException                                      = # Logic
exception.
MgStreamIoException                                   = A stream IO
exception occurred.
[ErrorDescription]
MgContentDocumentNotEmpty                             = The content
document
is not empty.
MgContentNotNull                                      = The content is
not
null.
MgCoordinateDimensionDifferent                        = The coordinate
dimensions are different.
MgDataReaderIdNotFound                                = The data reader
ID
was not found.
MgDocumentIdentifierFilenameFailed                    = Failed to get
the
filename from the document identifier because no matching document path
found.
MgFeatureReaderIdNotFound                             = The feature
reader
ID was not found.
MgGroupAndRoleNotEmpty                                = Both the group
and
role are not empty.
MgHeaderDocumentNotEmpty                              = The header
document
is not empty.
MgInvalidAgfText                                      = The AGF text is
invalid because it failed to parse into a valid geometry object.
MgInvalidFeatureSpatialOperation                      = The feature
spatial
operation is invalid because it is not recognized.
MgInvalidLogType                                      = The log type is
MgInvalidMapPlotCollectionMapPlotInstruction          = The map plot is
invalid because it contains an unrecognized map plot instruction.
MgInvalidNode                                         = The node is
invalid
because it is not an element node or a document node.
MgInvalidWebTargetType                                = The web target
type
MgInvalidWebTargetViewerType                          = The web target
viewer type is invalid because it is not recognized.
MgInvalidWebWidgetType                                = The web widget
type
[FeatureService]
MgInvalidFdoProvider                                  = Invalid Feature
Provider specified.
MgBatchInsertNotSupported                             = Provider does
not
support batch insert. Only one Feature instance is allowed.
MgNoFeaturesForInsert                                 = No Features for
Insert supplied
Lic. Jorge Rubio
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
