[mapguide-internals] Individual Contributor License Agreement andSpanish Localization
Jorge Rubio j.e.rubio at gmail.com
Tue Mar 20 11:20:06 EDT 2007
It's perferct. It gives me an exactly idea what the error or exception
means.
2007/3/20, Tom Fukushima <tom.fukushima at autodesk.com>:
> Hi Jorge,
> I won't be able to get anyone to look at it this week; however, someone
> may be able to start on it next week.
> What they will be doing is a search through the code for occurrences of
> the Exception or ErrorDescription name and looking at the method that it
> occurs in.  For example, I just did a search on
> "MgCoordinateSystemMeasureFailedException" and found that it could be
> raised from the following methods:
> ///<summary>
> /// Measures the euclidian distance between two coordinates.
> ///</summary>
> ///<param name="coord1">
> /// An MgCoordinate that defines the starting coordinate.
> ///</param>
> ///<param name="coord2">
> /// An MgCoordinate that defines the ending coordinate.
> ///</param>
> ///<returns>
> /// The euclidean distance from coord1 to coord2 in coordinate system
> units.
> ///</returns>
> double MgCoordinateSystem::MeasureEuclideanDistance(MgCoordinate*
> coord1, MgCoordinate* coord2)
> ///<summary>
> /// Measures the distance between two coordinates.
> /// This function uses the coordinate systems ellipsoid
> /// definition and a great circle algorithm to produce the result.
> ///</summary>
> ///</param>
> ///</param>
> ///<returns>
> /// The great circle distance from coord1 to coord2 in coordinate system
> units.
> ///</returns>
> double MgCoordinateSystem::MeasureGreatCircleDistance(MgCoordinate*
> ///<summary>
> /// Computes the distance between two coordinates.
> ///</summary>
> /// An MgCoordinate that specifies the first coordinate.
> ///</param>
> /// An MgCoordinate that specifies the second coordinate.
> ///</param>
> ///<returns>
> /// The distance between coord1 and coord2 as a double in coordinate
> system units.
> ///</returns>
> double MgCoordinateSystemMeasure::GetDistance(MgCoordinate* coord1,
> Is the above what you are looking for?
> Thanks
> Tom
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jorge
> Rubio
> Sent: Monday, March 19, 2007 1:21 PM
> To: MapGuide Internals Mail List
> Subject: [mapguide-internals] Individual Contributor License Agreement
> Hi friends
> I sent a signed Individual Contributor License Agreement by fax as was
> suggested when I sent the first e-mail offering spanish localization.
> In order to do an accurate translation to spanish I need more info about
> what the following exceptions and error description mean and when they
> are achieved.
> When I finish translation, files will uploaded following Tom
> instructions.
> [Exceptions]
> MgCoordinateSystemMeasureFailedException              = The coordinate
> system measure failed.
> MgDwfSectionNotFoundException                         = The specified
> section was not found: %1
> MgDwfSectionResourceNotFoundException                 = The specified
> section resource was not found: %1
> MgEmptyFeatureSetException                            = The feature set
> is
> empty.
> MgEndOfStreamException                                = End of stream
> exception.
> MgFeatureServiceException                             = Feature Service
> exception - %1
> MgInvalidCastException                                = Invalid cast.
> MgInvalidDwfSectionException                          = Invalid DWF
> section:
> %1
> MgInvalidFeatureSourceException                       = Feature Source -
> %1
> MgInvalidLogEntryException                            = An invalid log
> entry
> was found.
> MgInvalidOperationVersionException                    = The requested
> operation version is invalid.
> MgInvalidResourcePreProcessingTypeException           = Invalid resource
> pre-processing type.
> MgInvalidStreamHeaderException                        = Invalid stream
> header exception.
> MgLengthException                                     = A length
> exception
> occurred.
> MgLogicException                                      = # Logic
> exception.
> MgStreamIoException                                   = A stream IO
> exception occurred.
> [ErrorDescription]
> MgContentDocumentNotEmpty                             = The content
> document
> is not empty.
> MgContentNotNull                                      = The content is
> not
> null.
> MgCoordinateDimensionDifferent                        = The coordinate
> dimensions are different.
> MgDataReaderIdNotFound                                = The data reader
> ID
> was not found.
> MgDocumentIdentifierFilenameFailed                    = Failed to get
> the
> filename from the document identifier because no matching document path
> found.
> MgFeatureReaderIdNotFound                             = The feature
> reader
> ID was not found.
> MgGroupAndRoleNotEmpty                                = Both the group
> and
> role are not empty.
> MgHeaderDocumentNotEmpty                              = The header
> document
> is not empty.
> MgInvalidAgfText                                      = The AGF text is
> invalid because it failed to parse into a valid geometry object.
> MgInvalidFeatureSpatialOperation                      = The feature
> spatial
> operation is invalid because it is not recognized.
> MgInvalidLogType                                      = The log type is
> MgInvalidMapPlotCollectionMapPlotInstruction          = The map plot is
> invalid because it contains an unrecognized map plot instruction.
> MgInvalidNode                                         = The node is
> invalid
> because it is not an element node or a document node.
> MgInvalidWebTargetType                                = The web target
> type
> MgInvalidWebTargetViewerType                          = The web target
> viewer type is invalid because it is not recognized.
> MgInvalidWebWidgetType                                = The web widget
> type
> [FeatureService]
> MgInvalidFdoProvider                                  = Invalid Feature
> Provider specified.
> MgBatchInsertNotSupported                             = Provider does
> not
> support batch insert. Only one Feature instance is allowed.
> MgNoFeaturesForInsert                                 = No Features for
> Insert supplied
> Lic. Jorge Rubio
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Lic. Jorge Rubio
More information about the mapguide-internals mailing list
