[mapguide-internals] initialization error
Mike Adair madair at dmsolutions.ca
Tue Sep 11 09:27:32 EDT 2007
I'm having a problem with MapGuide OS (1.2.0) starting up on my laptop,
especially after it has hibernated or been moved to a different
network.  The error in the logs is:
PHP Fatal error:  Uncaught exception
'mgconfigurationloadfailedexception' in Unknown on line 0
(This is from Fusion's CreateSession.php which normally works when
MapGuide is up and running correctly).
I was getting the same message using 1.2.0 RC2(?) so I uninstalled and
then re-installed the stable release, which seemed to fix the problem
for the day yesterday, but it has now re-appeared this morning.  I'd
rather not spend the day watching Vista reboot again, does anyone have
any suggestions to fix this?
Thanks in advance,
Mike Adair
More information about the mapguide-internals mailing list
