[mapguide-internals] initialization error
Robert Bray rbray at robertbray.net
Tue Sep 11 11:37:41 EDT 2007
Mike,
You can get around it by simply restarting the MapGuide 1.2 Server
service after your laptop wakes up. This has been a persistent thorn in
my side for sometime, and this is the best workaround I have found. I
think there is also a track ticket for this somewhere, but it has not
been addressed yet.
Bob
Mike Adair wrote:
> Hi,
> I'm having a problem with MapGuide OS (1.2.0) starting up on my laptop,
> especially after it has hibernated or been moved to a different
> network.  The error in the logs is:
> PHP Fatal error:  Uncaught exception
> 'mgconfigurationloadfailedexception' in Unknown on line 0
> (This is from Fusion's CreateSession.php which normally works when
> MapGuide is up and running correctly).
> I was getting the same message using 1.2.0 RC2(?) so I uninstalled and
> then re-installed the stable release, which seemed to fix the problem
> for the day yesterday, but it has now re-appeared this morning.  I'd
> rather not spend the day watching Vista reboot again, does anyone have
> any suggestions to fix this?
> Thanks in advance,
> Mike Adair
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
