[mapguide-internals] MapGuide Comments
Kenneth, GEOGRAF A/S ks at geograf.dk
Sat Sep 15 13:22:23 EDT 2007
Yes, you are right. The client should have a copy of the current map view.
I still think that the current map view should be present on the server,
and then
reset on the client after retrival of a map. The same way the legend
currently works.
Regards, Kenneth, GEOGRAF A/S
Haris Kurtagic skrev:
> First of all, thank you for sharing your thoughts.
> I think client had to keep data about current Map view. For example if
> you would like to Zoom in, client would recalculate new scale and send
> it to server.
> There is no server command for change scale by 1.5 ( and also that type
> of "incremental" command would be inappropriate) and doing calls get
> scale - recalculate - send back doesn't sound right.
> I am now looking at Map as data, data with state ( existing data from
> features, new data ).
> View of Map (Image) I look as stateless.
> When I am thinking about this than I try to draw parallel between
> Map/Image and Table/Query in database. Map is a Table in database.
> Generating image is similar to generating view on your table data by
> sending parameters ( center ,scale ,layers on/off ,...).
> Haris
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of
> Sent: Thursday, September 13, 2007 9:23 AM
> To: MapGuide Internals Mail List
> Subject: Re: [mapguide-internals] MapGuide Comments
> I agree with your view that there should not be duplicates of data.
> I also believe that the client should be stateless (oposite of you I
> think?).
> My reason for this is that all manipulation of the map is done on the
> server.
> If there is some state on the client (as there is now), it is sometimes
> necessary to perform:
> Client Event -> Server Action -> Client Feedback -> More server ->
> Client feedback
> If all states are on the server, this would never be needed.
> Someone already pointed out that a server session is necessary for
> keeping temporary markuplayers and the like.
> The reason that the map state is also stored in the session is speed (in
> my best guess).
> It is not stored as an Xml, but a binary version of the MapDefinition,
> with added info.
> The map's layers gets info from the LayerDefinition (featuresource,
> geometrycolumn, etc), so there is only one
> repository access when manipulating the map.
> I have mentioned before that this is a bad solution, as the format of
> the binary Runtime Map, is heavily tied to
> the internal structures and constants in the MapGuide server code. This
> makes it very inacessible without using
> the existing API wrappers. My RFC# 21, is an attempt to fix that
> problem, but I have a feeling that your REST model will
> perform this and more.
> The method for storing the binary Runtime map, is creating an empty Map
> resource (not MapDefinition).
> The Map contains <Map />, but has attached a ResourceData file, that
> contains this binary format.
> I also feel that this is not a pretty way to implement it, but it works.
> This approach means that it is possible to store multiple views on a
> map, either by different dummy resources,
> or by multiple resourcedata files. I am not aware of how well the client
> is able to cope with this, but I know that the
> server has the ResourceData filenames hardcoded.
> I think that the client data is mainly thought of as a way of decreasing
> server calls. It keeps a list of visible
> layers, current zoom etc.
> I hope that makes sense, and can help you decide what to do with the
> sessions.
>> Keeping additional data in session sounds ok.
>> Keeping Map state is something I am not sure off.
>> To keep state in two places client and server doesn't sound right.
>> Also, there could be use case where several different views (Map
> State)
>> on same Map/Sesssion data would be implemented.
>> I am trying to understand implication's of Map/Session design and
> thank
>> you for your help.
>> Haris
> Robert
>> Bray
>> Sent: Thursday, September 13, 2007 5:32 AM
>> Right and it is not just buffers. Any kind of spatial analysis
> typically
>> leads to temporary data. Redline/markup and/or live data edit would
> also
>> typically be kept in a session until the user was ready to save or
>> commit their changes to a permanent data store.
>> Also keeping map state in a session means smaller packets can be sent
>> from client to server. E.g. the server only needs to know the delta in
>> layer state, not the visibility of all layers in order to render a
> map.
>> On the web today this is not all that important, but if we wanted to
>> support wireless/mobile clients in the future then this is pretty
>> attractive.
>> Bob
>> Haris Kurtagic wrote:
>>> Yes, I was also thinking about returning all images at once, I read
>>> about this Image strips (not familiar with those) but sounds like way
>> to
>>> go.
>>> Buffers, I forgot about those.
>>> Thank you,
>>> Haris
>> Robert
>>> Bray
>>> Sent: Wednesday, September 12, 2007 12:53 AM
>>> Harris,
>>> I could not agree more on your first point. In fact I would love to
>>> optimize that to send some kind of legend image strip in one
> operation
>>> to avoid all the round-trips.
>>> As for this comment:
>>>  >>I am setting Map view parameters and request for image in one
>>> request,
>>>  >>good or bad ?
>>> I think your approach is good. In fact that is the way the DWF Viewer
>>> works as a client.
>>> Sessions are necessary for other stuff, like temporary layers, data,
>>> etc. A buffer for example creates a temporary SDF and layer. You can
>>> then use that SDF for further geo-processing, etc.
>>> Thanks,
>>> Bob
>>>> I am working on MapGuide RESTful service and digging deep into
>>> MapGuide.
>>>> I have a lot of good words on what Autodesk guys did, good job.
>>>> I would like to comment on things that I don't like or understand
> and
>>>> hopefully to hear other opinions.
>>>> 1.       Legend Image Icon creation is very paintfull and error
>> prone.
>>>> To request for Icon you need to send few parameters scale, theme
> rule
>>>> index, geometry type,...
>>>> What is happing is that viewer's are deciding on geometry type not
> on
>>>> feature source geometry type but reading from XML ( PointStyle,
>>>> LineStyle, Polygon, Combo ) by string tag.
>>>> Then they will convert it into geometry type (and wrongly for
>>> ComboStyle
>>>> - will go to Multi Point). Server rendering is expecting real
>> geometry
>>>> type to find appropriate feature style (getting feature source and
>>>> correct geometry type would be even more overhead).
>>>> I see several problems: here viewers have hard-coded schema
> elements,
>>>> not correctly setting required geometry type, exception's on wrong
>>>> scale, exception if data on server is changed.
>>>> One of problems is if server can't figure out rule for example
>> setting
>>>> incorrect scale will crash web-tier badly ( null-pointer access).
>>>> This can be repeated with Sheboygan example and if you send request
>>> for
>>>> District legend icon with scale=0, it will not find it and will
>> return
>>>> null image and agent crashes ( HttpGetLegendImage needs if in 134
>> line
>>>> or throw exception in server).
>>>> What I think would be right is to have Id for rule so you would
>> simple
>>>> request for image by id instead of ( scale, geometry type, rule
> index
>>>> I wrote a lot about not so "important" thing but it took us a lot of
>>>> time :)
>>>> 2. Session - what are reasons for having session's ?
>>>> To store Map runtime parameters ( center, scale layers show/hide,
>>>> selection). Viewers are keeping this parameters of map and basically
>>>> doing two requests one to set these properties to runtime map and
>>>> another one to request image.
>>>> To store user credentials - session as token, that I think is  OK.
>> request,
>>>> good or bad ?
>>>> Thanks ,
>>>> Haris
>>>> _______________________________________________
>>>> mapguide-internals mailing list
>>>> mapguide-internals at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
