[mapguide-internals] MapGuide Comments
Paul Spencer pspencer at dmsolutions.ca
Tue Sep 18 21:54:07 EDT 2007
Sorry to come into this discussion so late, I think Harris and
Kenneth have more-or-less expressed the opinions that I would have so
I will just reiterate support for this.
It is critical for the client to maintain most of the state
information about the map (extents, size, layer & group visibility,
etc).  The necessity of calling the server to set this in the session
is, frankly, a pain.  The client already has sufficient information
to figure out the visible extents in the correct aspect ratio etc.
There is a necessity to be able to store a copy of the map in the
session to be able to make structural changes to it, such as adding
or removing layers, changing layer order etc.
I also prefer to have the selection maintained in the server rather
than the client, but I am willing to change my mind on this.  For
large selections, it seems like a lot of information to be moving
back and forth if the details of the selection are not required on
the client ...
Fusion would benefit greatly from a RESTful API such as Harris is
working on, and I am excited to see how it evolves and how we can
take advantage of it.
Cheers
Paul
On 15-Sep-07, at 1:22 PM, Kenneth, GEOGRAF A/S wrote:
> Yes, you are right. The client should have a copy of the current
> map view.
> I still think that the current map view should be present on the
> server, and then
> reset on the client after retrival of a map. The same way the
> legend currently works.
> Regards, Kenneth, GEOGRAF A/S
> Haris Kurtagic skrev:
>> First of all, thank you for sharing your thoughts.
>> I think client had to keep data about current Map view. For
>> example if
>> you would like to Zoom in, client would recalculate new scale and
>> send
>> it to server.
>> There is no server command for change scale by 1.5 ( and also that
>> type
>> of "incremental" command would be inappropriate) and doing calls get
>> scale - recalculate - send back doesn't sound right.
>> I am now looking at Map as data, data with state ( existing data from
>> features, new data ).
>> View of Map (Image) I look as stateless.
>> When I am thinking about this than I try to draw parallel between
>> Map/Image and Table/Query in database. Map is a Table in database.
>> Generating image is similar to generating view on your table data by
>> sending parameters ( center ,scale ,layers on/off ,...).
>> Haris
>> -----Original Message-----
>> From: mapguide-internals-bounces at lists.osgeo.org
>> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of
>> Sent: Thursday, September 13, 2007 9:23 AM
>> To: MapGuide Internals Mail List
>> Subject: Re: [mapguide-internals] MapGuide Comments
>> I agree with your view that there should not be duplicates of data.
>> I also believe that the client should be stateless (oposite of you
>> I think?).
>> My reason for this is that all manipulation of the map is done on
>> the server.
>> If there is some state on the client (as there is now), it is
>> sometimes necessary to perform:
>> Client Event -> Server Action -> Client Feedback -> More server ->
>> Client feedback
>> If all states are on the server, this would never be needed.
>> Someone already pointed out that a server session is necessary for
>> keeping temporary markuplayers and the like.
>> The reason that the map state is also stored in the session is
>> speed (in
>> my best guess).
>> It is not stored as an Xml, but a binary version of the
>> MapDefinition, with added info.
>> The map's layers gets info from the LayerDefinition
>> (featuresource, geometrycolumn, etc), so there is only one
>> repository access when manipulating the map.
>> I have mentioned before that this is a bad solution, as the format
>> of the binary Runtime Map, is heavily tied to
>> the internal structures and constants in the MapGuide server code.
>> This makes it very inacessible without using
>> the existing API wrappers. My RFC# 21, is an attempt to fix that
>> problem, but I have a feeling that your REST model will
>> perform this and more.
>> The method for storing the binary Runtime map, is creating an
>> empty Map resource (not MapDefinition).
>> The Map contains <Map />, but has attached a ResourceData file,
>> that contains this binary format.
>> I also feel that this is not a pretty way to implement it, but it
>> works.
>> This approach means that it is possible to store multiple views on
>> a map, either by different dummy resources,
>> or by multiple resourcedata files. I am not aware of how well the
>> client
>> is able to cope with this, but I know that the
>> server has the ResourceData filenames hardcoded.
>> I think that the client data is mainly thought of as a way of
>> decreasing
>> server calls. It keeps a list of visible
>> layers, current zoom etc.
>> I hope that makes sense, and can help you decide what to do with
>> the sessions.
>>> Keeping additional data in session sounds ok.
>>> Keeping Map state is something I am not sure off.
>>> To keep state in two places client and server doesn't sound right.
>>> Also, there could be use case where several different views (Map
>> State)
>>> on same Map/Sesssion data would be implemented.
>>> I am trying to understand implication's of Map/Session design and
>> thank
>>> you for your help.
>>> Haris
>> Robert
>>> Bray
>>> Sent: Thursday, September 13, 2007 5:32 AM
>>> Right and it is not just buffers. Any kind of spatial analysis
>> typically
>>> leads to temporary data. Redline/markup and/or live data edit would
>> also
>>> typically be kept in a session until the user was ready to save
>>> or commit their changes to a permanent data store.
>>> Also keeping map state in a session means smaller packets can be
>>> sent from client to server. E.g. the server only needs to know
>>> the delta in
>>> layer state, not the visibility of all layers in order to render a
>> map.
>>> On the web today this is not all that important, but if we wanted
>>> to support wireless/mobile clients in the future then this is
>>> pretty attractive.
>>> Bob
>>> Haris Kurtagic wrote:
>>>> Yes, I was also thinking about returning all images at once, I read
>>>> about this Image strips (not familiar with those) but sounds
>>>> like way
>>> to
>>>> go.
>>>> Buffers, I forgot about those.
>>>> Thank you,
>>>> Haris
>>> Robert
>>>> Bray
>>>> Sent: Wednesday, September 12, 2007 12:53 AM
>>>> Harris,
>>>> I could not agree more on your first point. In fact I would love
>>>> to optimize that to send some kind of legend image strip in one
>> operation
>>>> to avoid all the round-trips.
>>>> As for this comment:
>>>>  >>I am setting Map view parameters and request for image in one
>>>> request,
>>>>  >>good or bad ?
>>>> I think your approach is good. In fact that is the way the DWF
>>>> Viewer
>>>> works as a client.
>>>> Sessions are necessary for other stuff, like temporary layers,
>>>> data, etc. A buffer for example creates a temporary SDF and
>>>> layer. You can then use that SDF for further geo-processing, etc.
>>>> Thanks,
>>>> Bob
>>>>> I am working on MapGuide RESTful service and digging deep into
>>>> MapGuide.
>>>>> I have a lot of good words on what Autodesk guys did, good job.
>>>>> I would like to comment on things that I don't like or understand
>> and
>>>>> hopefully to hear other opinions.
>>>>> 1.       Legend Image Icon creation is very paintfull and error
>>> prone.
>>>>> To request for Icon you need to send few parameters scale, theme
>> rule
>>>>> index, geometry type,...
>>>>> What is happing is that viewer's are deciding on geometry type not
>> on
>>>>> feature source geometry type but reading from XML ( PointStyle,
>>>>> LineStyle, Polygon, Combo ) by string tag.
>>>>> Then they will convert it into geometry type (and wrongly for
>>>> ComboStyle
>>>>> - will go to Multi Point). Server rendering is expecting real
>>> geometry
>>>>> type to find appropriate feature style (getting feature source and
>>>>> correct geometry type would be even more overhead).
>>>>> I see several problems: here viewers have hard-coded schema
>> elements,
>>>>> not correctly setting required geometry type, exception's on wrong
>>>>> scale, exception if data on server is changed.
>>>>> One of problems is if server can't figure out rule for example
>>> setting
>>>>> incorrect scale will crash web-tier badly ( null-pointer access).
>>>>> This can be repeated with Sheboygan example and if you send
>>>>> request
>>>> for
>>>>> District legend icon with scale=0, it will not find it and will
>>> return
>>>>> null image and agent crashes ( HttpGetLegendImage needs if in 134
>>> line
>>>>> or throw exception in server).
>>>>> What I think would be right is to have Id for rule so you would
>>> simple
>>>>> request for image by id instead of ( scale, geometry type, rule
>> index
>>>>> I wrote a lot about not so "important" thing but it took us a
>>>>> lot of
>>>>> time :)
>>>>> 2. Session - what are reasons for having session's ?
>>>>> To store Map runtime parameters ( center, scale layers show/hide,
>>>>> selection). Viewers are keeping this parameters of map and
>>>>> basically
>>>>> doing two requests one to set these properties to runtime map and
>>>>> another one to request image.
>>>>> To store user credentials - session as token, that I think is  OK.
>>> request,
>>>>> good or bad ?
>>>>> Thanks ,
>>>>> Haris
>>>>> _______________________________________________
>>>>> mapguide-internals mailing list
>>>>> mapguide-internals at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
|Paul Spencer                          pspencer at dmsolutions.ca    |
|Chief Technology Officer                                         |
|DM Solutions Group Inc                http://www.dmsolutions.ca/ |
More information about the mapguide-internals mailing list
