[mapguide-internals] MapGuide RFC 55 - Switch from PROJ4 to CS-Map coordinate system library
Jason Birch Jason.Birch at nanaimo.ca
Thu Aug 7 23:47:30 EDT 2008
Hi Hugues!
Wow, that was quick; maybe GDAL won't beat MapGuide in using CS-Map after all :)
I guess the original intention of having a compile-time switch so that users can choose one or the other has gone out the window?  I'm not necessarily against this--it's more overhead to maintain both--just surprised at the change.
Will this affect sites that are running MapGuide alongside other open source PROJ.4-based applications that do on-the-fly projections on the same data; is it possible that users see large differences from one application to the next?
What are the implications for existing installs?  Is there a potential that spatial contexts have been recorded to the repository (in SC overrides, native map projections, etc) or FDO data stores that are incompatible with CS-Map?  If so, how will we support users running into this problem?  Is there a potential for a utility application that scans the repository and tests whether CS-Map can recognize the WKT so that users can identify and resolve any problems before upgrading?
Jason
Subject: [mapguide-internals] MapGuide RFC 55 - Switch from PROJ4 to CS-Map coordinate system library
I would like to submit "MapGuide RFC 55 - Switch from PROJ4 to CS-Map coordinate system library" for review and comment.
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc55
Thanks,
Hugues
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
