[mapguide-internals] sp_cursorfetch
ljv johan.vikstrom at gmail.com
Mon Nov 24 09:36:52 EST 2008
The data is dynamic, it's based on current status of objects and the
effective userrights to a single object. I do not think we can prepare a
table with the data. There is around 20k of objects, most of them can be
displayed at the same time. So I get in worst case 20k of unwanted trips to
the sql server.
zspitzer wrote:
> how dynamic is the data?
> you may find just creating a table from the view + indexing solves the
> problem
> z
> On Mon, Nov 24, 2008 at 11:40 PM, ljv <johan.vikstrom at gmail.com> wrote:
>> We are running on an IIS server and has a MSSQL server as database.
>> Since the data query is to complex to build in mapguide we use a view.
>> When we test we find that the use of sp_cursorfetch when reading the data
>> causes massive cpu load and it is extremly slow.
>> Is there anyway to get the mgserver to bulkread data instead of single
>> fetching, or perhaps to use storedprocedures, ?
>> View this message in context:
>> http://www.nabble.com/sp_cursorfetch-tp20317839p20317839.html
>> Sent from the MapGuide Internals mailing list archive at Nabble.com.
>> mapguide-internals mailing list
>> mapguide-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> Zac Spitzer -
> http://zacster.blogspot.com
> http://ennoble.dreamhosters.com/mapguide-central/
> +61 405 847 168
View this message in context: http://www.nabble.com/sp_cursorfetch-tp20317839p20662030.html
More information about the mapguide-internals mailing list
