[mapguide-internals] Tweaking serverconfig.ini defaults for 2.1
Zac Spitzer zac.spitzer at gmail.com
Wed Oct 15 19:02:26 EDT 2008
Hi Tom,
Definitely the CacheSize value, i agree with Trevor's rationale for
with leaving SDF/SHP excluded .
from the file header "The following configuration is based on a single
CPU with a single core."
Given that you pretty much can't even buy a single core server these
days, I think these
values could be tweaked up. Ideally shipping with a number of default
configs i.e .
serverconfig.ini  -- default optimised for a dual core machine
serverconfig_4_core.ini  -- default optimised for a quad core machine
serverconfig_8_core.ini  -- default optimised for a dual quad core machine
It's not 100% clear from the file either which bits affect what
I am assuming that ClientConnectionProperties relates to mapagent.fcgi calls
and SiteConnectionProperties relates to Web API calls?
On Thu, Oct 16, 2008 at 8:27 AM, Tom Fukushima
<tom.fukushima at autodesk.com> wrote:
> Hi Zac,
> What do you suggest for changes?
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
> Sent: Wednesday, October 08, 2008 10:19 AM
> To: MapGuide Internals Mail List
> Subject: [mapguide-internals] Tweaking serverconfig.ini defaults for 2.1
> What do people think about tweaking the defaults for serverconfig.ini?
> My understanding is that the CacheSize=100 setting is a bit small for
> everything beyond a few basic maps
> Also what about the SDF & SHP with DataConnectionPoolExcludedProviders
> z
> Zac Spitzer -
> http://zacster.blogspot.com (My Blog)
> +61 405 847 168
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer -
+61 405 847 168
More information about the mapguide-internals mailing list
