[mapguide-internals] Tweaking serverconfig.ini defaults for 2.1
Zac Spitzer zac.spitzer at gmail.com
Tue Oct 21 05:00:21 EDT 2008
Does the cachesize need to be limited?  generally speaking
Making it an optional limit, given the assumption that when mapguide
was initially
written the average server had a lot less memory and these days most
servers tend
to have a lot of ram, would mean than only the heaviest users would
ever need to set
this value (ie a limit).
Anyone know what the average size in ram of these cache entries are?
This way MapGuide could avoid being cache constricted for the majority of users,
those who do need this can
z
On Thu, Oct 16, 2008 at 10:02 AM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> Hi Tom,
> Definitely the CacheSize value, i agree with Trevor's rationale for
> with leaving SDF/SHP excluded .
> from the file header "The following configuration is based on a single
> CPU with a single core."
> Given that you pretty much can't even buy a single core server these
> days, I think these
> values could be tweaked up. Ideally shipping with a number of default
> configs i.e .
> serverconfig.ini  -- default optimised for a dual core machine
> serverconfig_4_core.ini  -- default optimised for a quad core machine
> serverconfig_8_core.ini  -- default optimised for a dual quad core machine
> It's not 100% clear from the file either which bits affect what
> I am assuming that ClientConnectionProperties relates to mapagent.fcgi calls
> and SiteConnectionProperties relates to Web API calls?
> On Thu, Oct 16, 2008 at 8:27 AM, Tom Fukushima
> <tom.fukushima at autodesk.com> wrote:
>> Hi Zac,
>> What do you suggest for changes?
>> -----Original Message-----
>> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
>> Sent: Wednesday, October 08, 2008 10:19 AM
>> To: MapGuide Internals Mail List
>> Subject: [mapguide-internals] Tweaking serverconfig.ini defaults for 2.1
>> What do people think about tweaking the defaults for serverconfig.ini?
>> My understanding is that the CacheSize=100 setting is a bit small for
>> everything beyond a few basic maps
>> Also what about the SDF & SHP with DataConnectionPoolExcludedProviders
>> z
>> Zac Spitzer -
>> http://zacster.blogspot.com (My Blog)
>> +61 405 847 168
>> mapguide-internals mailing list
>> mapguide-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> Zac Spitzer -
> +61 405 847 168
Zac Spitzer -
+61 405 847 168
More information about the mapguide-internals mailing list
