[mapguide-internals] Installer progress
Jason Birch Jason.Birch at nanaimo.ca
Thu Apr 23 09:57:45 EDT 2009
I think so.
Neither of the script mappings works as expected; hitting any page that calls one of the isapi extensions results in a 500 server error.  I think the installer missed adding the full path, but even after I fixed that manually, removed and recreated the entire mapguide vdir, same error.
Sorry for the poor initial description :)
Jason
----- Original Message -----
From: mapguide-internals-bounces at lists.osgeo.org <mapguide-internals-bounces at lists.osgeo.org>
To: mapguide-internals at lists.osgeo.org <mapguide-internals at lists.osgeo.org>
Sent: Thu Apr 23 03:01:07 2009
Subject: RE: [mapguide-internals] Installer progress
It could be related to this one.
http://trac.osgeo.org/mapguide/ticket/958
- Jackie
alucas wrote:
> Hi Jason,
> There is an active ticket for the problem? If yes, please, tell me the ID
> or explain to me the detailled problem. I'll try to help.
> Regards.
> Jason Birch wrote:
>> Well, the good news is that an IIS install works fine on W2K3, after a
>> fix to stop a missing .Net from causing the installer to roll back.
>> The bad news is that an IIS install under XP fails miserably, and I have
>> no idea what is causing the problem.  I can't even get it working by
>> setting up the apps and mappings manually.  It's been so long since I've
>> dealt with IIS 5.1 that I don't even know where to start.
>> If anyone has an idea of what may be causing this, or has time to test
>> the current installer with Apache/PHP, Apache/JSP (any platform) or
>> Vista, that would be cool.
>> I'm not going to be able to get back to this stuff for a couple days.
>> Jason
>> ________________________________________
>> From: Jason Birch
>> Sent: Wednesday, April 22, 2009 3:37 AM
>> Subject: [mapguide-internals] Installer progress
>> I've uploaded a new installer (that also includes Bruce's FDO connection
>> manager fixes and Walt's rendering enhancements for those who are
>> curious) to the following directory:
>> http://download.osgeo.org/mapguide/testing/
>> -or-
>> ftp://download.osgeo.org/mapguide/testing/_______________________________________________
>> mapguide-internals mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
View this message in context: http://n2.nabble.com/Installer-progress-tp2675328p2682063.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
