[mapguide-internals] Review RefineErrorMessage.patch
Christine Bao Christine.Bao at autodesk.com
Tue Aug 11 05:17:01 EDT 2009
Hi all,
     Would you please review patch for ticket http://trac.osgeo.org/mapguide/ticket/1026? Thank you.
      Here is the comment:
Add patch http://trac.osgeo.org/mapguide/attachment/ticket/1026/RefineErrorMessage.patch.
There are two fixes in this patch:
1. If the error message contains "\n" or "\t", the string in status text will be converted into "\\n" and "\\t". Here format the message again to show the correct style.
2. Remove "Fusion Error" stuff for those message come from MapGuide exception because it's too technical.
Thanks & regards,
Christine
More information about the mapguide-internals mailing list
