[mapguide-internals] RFC 49 parameter logging delimiters tweak
Zac Spitzer zac.spitzer at gmail.com
Mon Feb 2 17:24:18 EST 2009
sweet!
On Tue, Feb 3, 2009 at 6:59 AM, Bruce Dechant
<bruce.dechant at autodesk.com> wrote:
> Zac,
> I just submitted a fix for this as the logging enhancements for RFC49 should be using the serverconfig.ini setting LogsDelimiter for the delimiter character and not a hard coded comma character.
> Thanks,
> Bruce
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
> Sent: Friday, December 26, 2008 10:54 PM
> To: MapGuide Internals Mail List
> Subject: [mapguide-internals] RFC 49 parameter logging delimiters tweak
> Currently the delimiters for the parameters use a comma as the
> delimiter between the options,
> it makes parsing the parameters harder than neccesary as there are
> often commas in the WKT
> Resource=Library://Samples/Sheboygan/Data/VotingDistricts.FeatureSource,ClassName=SDF_2_Schema:VotingDistricts,Options={{Operator=1}{GeomProp=Data}{GeomOp=10}{Geometry=POLYGON
> ((-87.783866628374042 43.691398128787803, -87.676641873488435
> 43.691398128787803, -87.676641873488435 43.797520000480297,
> -87.783866628374042 43.797520000480297, -87.783866628374042
> 43.691398128787803))}}
> Would it make sense to use a semi-colon instead, just to make parsing
> this easier?
> I am writing a up little php script which parses the Trace.log and
> re-executes the
> query for performance profiling
> Enhancing the END entries by adding the BGN parameters and elapsed time, maybe
> as level 4 would make the log files useful without pre-processing
> z
> Zac Spitzer -
> http://zacster.blogspot.com
> +61 405 847 168
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer -
+61 405 847 168
More information about the mapguide-internals mailing list
