[mapguide-internals] VOTE: Add Jackie Ng as a committer (Re: OSGeo Project Contributor agreements)
Tyler Mitchell (OSGeo) tmitchell at osgeo.org
Wed Feb 25 13:39:48 EST 2009
Hi Jackie,
I see I didn't add your name to the MapGuide list on the wiki page.
I guess yours is the first MGOS one I received, I had to start a new
table for it.  Does that make sense?
You should be good to go!
Tyler
On 24-Feb-09, at 4:08 PM, Jackie Ng wrote:
> I submitted two contributor agreements months ago (one for FDO and
> one for MGOS). I never knew if the MGOS one got accepted.
> 2008/10/15 Tyler Mitchell (OSGeo) <tmitchell at osgeo.org>
> Good to know!  Works for me, thank you.
> Bob - can we get MGOS onto the CLA somewhere?
> Begin forwarded message:
> From: "Jackie Ng" <jumpinjackie at gmail.com>
> Date: October 14, 2008 12:46:47 PM PDT (CA)
> To: "Tyler Mitchell (OSGeo)" <tmitchell at osgeo.org>
> Subject: Re: OSGeo Project Contributor agreements
> Hi Tyler,
> The MGOS one does not mention the actual project name. Hence I
> wrote it on the back of the document.
> See for yourself: http://mapguide.osgeo.org/files/Individual%
> 20Contributor%20Agreement.pdf
> - Jackie
> Hi Jackie,
> Sorry for a slow response, I've been on vacation.  I received your
> documents, thank you.  Did you keep a copy of them?  The reason I
> ask is that the FDO one is fine, but the other one did not mention
> what project it was for.  I will need you to resend that one.  I
> notice you say it is for MGOS - was that mentioned anywhere in the
> document?  I might just have a bad eyes.
> I keep track of all contributor agreements here:
> http://wiki.osgeo.org/wiki/Contributor_Agreements_Received
> Hope that helps.  I was going to follow up with anyway, so thank
> you for being in touch.  I'm your primary contact on this topic.
> Tyler
> On 6-Oct-08, at 2:23 AM, Jackie Ng wrote:
> Hi All,
> I recently (a week and a bit ago) mailed two signed Project
> Contributor agreement documents (one for MapGuide Open Source and
> one for Feature Data Objects), my questions are:
> 1) What is the usual turnaround time for Project Contributor
> agreements be processed?
> 2) How will I know if my mailed agreements have been accepted?
> Regards,
> - Jackie
> Blog: http://themapguyde.blogspot.com
> LinkedIn: http://www.linkedin.com/in/jackieng
> Twitter: http://twitter.com/jumpinjackie
> "A SQL query walks into a bar and sees two tables. He walks up to
> them and says 'Can I join you?'"
More information about the mapguide-internals mailing list
