[mapguide-internals] Installer - work in progress
Jason Birch
Jason.Birch at nanaimo.ca
Tue Mar 17 16:30:43 EDT 2009
Martin at EDSI has graciously placed a recent build of the installer in
the following temporary location:
http://gis.edsi.com/MapGuideOpenSource-2.1.0-Unofficial.msi
This will only be available for a limited time, and should not be
broadcast widely so their server doesn't get swamped, but it will give
you a chance to try out the new installer if you have been following
along but haven't had a chance to build your own yet. The installer
still needs considerable testing, especially to ensure that configurable
items get set correctly, that all OS / API language combinations work,
etc.
There are some known issues with IIS7, and if you want to install under
IIS7 you'll have to start up a command prompt "as Administrator" and run
it like:
msiexec /i MapGuideOpenSource-2.1.0-Unofficial.msi
Also, I thought I had resolved this (patch attached to ticket 911), but
Crispin had to manually install the Visual C++ runtime (VS2008 SP1) for
the installer to complete successfully.
If you run into problems, please update or enter new trac tickets under
the Installer component.
Thanks,
Jason
More information about the mapguide-internals
