[mapguide-internals] Installation directory structure
Zac Spitzer
zac.spitzer at gmail.com
Mon Mar 30 23:56:40 EDT 2009
no version number makes side by side installs tricky
and if you look at things like say ms office or autodesk apps
they both use a version number in the sub dir?
anyone know what's best practise these days in ms world?
guess it's different with later versions ?
z
2009/3/31 Jason Birch <Jason.Birch at nanaimo.ca>:
> Quick note: Agreed, but would prefer "MapGuide", without version number in path. And really, really, want to see data dir locations (logs, repos, packages, temp) remain configurable at install time.
> Jason
> ----- Original Message -----
> From: mapguide-internals-bounces at lists.osgeo.org <mapguide-internals-bounces at lists.osgeo.org>
> To: mapguide-internals at lists.osgeo.org <mapguide-internals at lists.osgeo.org>
> Sent: Mon Mar 30 19:21:38 2009
> Subject: [mapguide-internals] Installation directory structure
> Hi All,
> There seems to be some talk that the current directory structure used by the installer is not quite ideal. If so, then what should the ideal structure be?
> I would prefer something like:
> $INSTALLDIR = C:\Program Files\OSGeo\MapGuideOpenSource
> $INSTALLDIR\Server
> $INSTALLDIR\WebServerExtensions
> $INSTALLDIR\CSMap
> This would be like the structure of previous releases, except by default it goes under the 'OSGeo' name and it will work-around the fusion having hard-coded the web server extension path. Jason suggested locking down the Server and Webextension directories which I think is a good idea. The less number of configurable paths, the better.
> Thoughts?
> - Jackie
> P.S. I didn't come up with the initial directory structure. I just went with the flow :-)
> View this message in context: http://n2.nabble.com/Installation-directory-structure-tp2560810p2560810.html
> Sent from the MapGuide Internals mailing list archive at Nabble.com.
> mapguide-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals
