[mapguide-internals] Some code fixes for RFC 60
Walt Welton-Lair walt.welton-lair at autodesk.com
Fri May 8 02:23:37 EDT 2009
UV,
Two fixes:
* Change your GetResourceServiceForMapDef method in ServerTileService to simply return an MgResourceService* (properly addref'ed) and not a smart-pointer.  We don't have any methods which return smart-pointers.  It's up to the calling code to decide if it wants to wrap the method's return value in a smart-pointer.
* In MapLayer/Map.cpp you have numerous memory leaks.  You allocate a new STRCOLORLIST (assigning it to the m_colorPalette member variable), but don't delete it anywhere.  Instead you only call clear on the list, which isn't the same as deleting the object.  SetColorPalette also leaks any previously allocated m_colorPalette.  I would simply change m_colorPalette to be a STRCOLORLIST instead of a PSTRCOLORLIST.  GetColorPalette then returns the address of m_colorPalette, and SetColorPalette replaces the contents of m_colorPalette with the supplied palette.
Thanks,
Walt
 W       E         @__   __o
   A   T   R   @___    _ \<,_
     L           @_   (*)/ (*)
More information about the mapguide-internals mailing list
