[mapguide-internals] Stability and performance issues with MGOS 2.1
UV uvwild at gmail.com
Fri May 8 00:48:40 EDT 2009
That sounds great. I am happy to run and examine those fixes with our
150 layer Ozzy map.
Please consider using this opportunity to share your higher level
architectural insights and leave some remarks
in the source code  as this seems the best place to put it and the
easiest to write it into  or anywhere else.
Doing such complex analysis work seems a very good moment to leave a few
remarks here and there without a lot of effort
(compared to writing or completing an architecture document)
Any additional info in this direction is greatly appreciated, in
particular the not so obvious things or motivations for a chosen approach.
e.g. which logical processing an exception handler is responsible for
Thanks for your considerations.
Trevor Wekel wrote:
> Hi everyone,
> I just took a read through the meeting minutes from the PSC and there was some discussion around selection, performance, and stability with MGOS 2.1.  I have spent the last month investigating some of these issues and have some insights.  Haris and others, please contact me directly.
> I will be making some code submissions to fix a few things that I have already found.  These submission affect both MapGuide and Fdo.  And there will be more to come.  No use duplicating effort here between Autodesk and the community.  However, I could use some guinea pigs to test this stuff when I start to slam all this code in.
> Bruce has already submitted a patch for web tier/server connectivity on my behalf http://trac.osgeo.org/mapguide/changeset/3847.  Thanks Bruce!
> This change along with a previous submission related to repository tuning http://trac.osgeo.org/mapguide/changeset/3847 have brought MapGuide on Windows to a point where it can begin to handle concurrent user loads in excess of 200+ users, depending on data set.
> The next set of submissions which I need to make will deal with a variety of memory leaks in both MapGuide and Fdo.  Large selections in a multi-user environment with MGOS 2.1 will exhaust virtual memory.  I do have fixes in hand but have not tested it with all of the providers
> Thanks,
> Trevor
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
