[mapguide-internals] Re: 32 bit installer on build machine
Jackie Ng jumpinjackie at gmail.com
Sun Mar 21 18:38:42 EDT 2010
Hi Trevor,
The build.bat has an -a=generate option that rebuilds the wxs files from
scratch. The installer uses MgDev\Release as the default directory from
where Paraffin will generate its file list.
Because the MG output directory does not initially have the Apache, PHP and
Tomcat binaries, these need to be copied over. The -a=prepare option
fulfills this purpose.
I usually have paraffin.exe inside the Installer root directory.
After a successful run of MgDev\build.bat w/ default settings, I do the
following from the Installer directory:
build.bat -a=prepare
build.bat -a=generate
build.bat
- Jackie
View this message in context: http://n2.nabble.com/32-bit-installer-on-build-machine-tp4772724p4775079.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
