[mapguide-internals] Re: 32 bit installer on build machine
Tom Fukushima tom.fukushima at autodesk.com
Mon Mar 22 19:20:15 EDT 2010
I believe you can use http://mapguide.osgeo.org/files/mapguide/docs/2.0/viewerapi.html as the original source of the Viewer API.  Feel free to check that into svn if required.
I was also trying to get the source for the dev guide so that MGOS could work directly on that but never heard back (I'm still not happy about this, and sorry).
Tom
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Monday, March 22, 2010 5:08 PM
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] Re: 32 bit installer on build machine
> 3. The Web API reference installed under http://localhost/mapguide/help/
> contains lots of content.
> [JN] One of the things missing is the viewer API reference. That is not in
> svn. I don't know where the original source is.
More information about the mapguide-internals mailing list
