[mapguide-internals] Ubuntu 9.10 is MapGuide 2.2's best friend
Zac Spitzer
zac.spitzer at gmail.com
Wed Mar 31 19:52:59 EDT 2010
root at localhost:~# apt-get install odbcinst1debian1
Reading package lists... Done
Building dependency tree
Reading state information... Done
You might want to run `apt-get -f install' to correct these:
The following packages have unmet dependencies:
fdo-core: Depends: unixodbc (>= 2.2.11-1) but it is not going to be installed
fdo-rdbms: Depends: libmysqlclient15off (>= 5.0.27-1) but it is not
installable
odbcinst1debian1: Depends: libltdl7 (>= 2.2.6a) but it is not going
to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or
specify a solution).
2010/4/1 Zac Spitzer <zac.spitzer at gmail.com>:
> wow! this is great news Trevor!
> ok, on a fresh 9.10 linode server I got the following errors after all the wget-ting
> some of the dependencies aren't being auto resolved
> Selecting previously deselected package fdo-core.
> (Reading database ... 14291 files and directories currently installed.)
> Unpacking fdo-core (from fdo-core_3.5.0-5343_i386.deb) ...
> dpkg: dependency problems prevent configuration of fdo-core:
> fdo-core depends on odbcinst1debian1 (>= 2.2.11-3); however:
> Package odbcinst1debian1 is not installed.
> fdo-core depends on unixodbc (>= 2.2.11-1); however:
> Package unixodbc is not installed.
> dpkg: error processing fdo-core (--install):
> dependency problems - leaving unconfigured
> Errors were encountered while processing:
> fdo-core
> Selecting previously deselected package fdo-gdal.
> (Reading database ... 14746 files and directories currently installed.)
> Unpacking fdo-gdal (from fdo-gdal_3.5.0-5343_i386.deb) ...
> dpkg: dependency problems prevent configuration of fdo-gdal:
> fdo-gdal depends on fdo-core (>= 3.5.0-5343); however:
> Package fdo-core is not configured yet.
> dpkg: error processing fdo-gdal (--install):
> fdo-gdal
> Selecting previously deselected package fdo-kingoracle.
> (Reading database ... 14767 files and directories currently installed.)
> Unpacking fdo-kingoracle (from fdo-kingoracle_3.5.0-5343_i386.deb) ...
> Setting up fdo-kingoracle (3.5.0-5343) ...
> Selecting previously deselected package fdo-ogr.
> (Reading database ... 14786 files and directories currently installed.)
> Unpacking fdo-ogr (from fdo-ogr_3.5.0-5343_i386.deb) ...
> dpkg: dependency problems prevent configuration of fdo-ogr:
> fdo-ogr depends on fdo-core (>= 3.5.0-5343); however:
> dpkg: error processing fdo-ogr (--install):
> fdo-ogr
> Selecting previously deselected package fdo-postgis.
> (Reading database ... 14791 files and directories currently installed.)
> Unpacking fdo-postgis (from fdo-postgis_3.5.0-5343_i386.deb) ...
> dpkg: dependency problems prevent configuration of fdo-postgis:
> fdo-postgis depends on fdo-core (>= 3.5.0-5343); however:
> dpkg: error processing fdo-postgis (--install):
> fdo-postgis
> Selecting previously deselected package fdo-rdbms.
> (Reading database ... 14810 files and directories currently installed.)
> Unpacking fdo-rdbms (from fdo-rdbms_3.5.0-5343_i386.deb) ...
> dpkg: dependency problems prevent configuration of fdo-rdbms:
> fdo-rdbms depends on fdo-core (>= 3.5.0-5343); however:
> fdo-rdbms depends on libmysqlclient15off (>= 5.0.27-1); however:
> Package libmysqlclient15off is not installed.
> fdo-rdbms depends on odbcinst1debian1 (>= 2.2.11-3); however:
> fdo-rdbms depends on unixodbc (>= 2.2.11-1); however:
> dpkg: error processing fdo-rdbms (--install):
> fdo-rdbms
> Selecting previously deselected package fdo-sdf.
> (Reading database ... 14892 files and directories currently installed.)
> Unpacking fdo-sdf (from fdo-sdf_3.5.0-5343_i386.deb) ...
> dpkg: dependency problems prevent configuration of fdo-sdf:
> fdo-sdf depends on fdo-core (>= 3.5.0-5343); however:
> dpkg: error processing fdo-sdf (--install):
> fdo-sdf
> Selecting previously deselected package fdo-shp.
> (Reading database ... 14906 files and directories currently installed.)
> Unpacking fdo-shp (from fdo-shp_3.5.0-5343_i386.deb) ...
> dpkg: dependency problems prevent configuration of fdo-shp:
> fdo-shp depends on fdo-core (>= 3.5.0-5343); however:
> dpkg: error processing fdo-shp (--install):
> fdo-shp
> Selecting previously deselected package fdo-sqlite.
> (Reading database ... 14928 files and directories currently installed.)
> Unpacking fdo-sqlite (from fdo-sqlite_3.5.0-5343_i386.deb) ...
> dpkg: dependency problems prevent configuration of fdo-sqlite:
> fdo-sqlite depends on fdo-core (>= 3.5.0-5343); however:
> dpkg: error processing fdo-sqlite (--install):
> fdo-sqlite
> Selecting previously deselected package fdo-wfs.
> (Reading database ... 14933 files and directories currently installed.)
> Unpacking fdo-wfs (from fdo-wfs_3.5.0-5343_i386.deb) ...
> dpkg: dependency problems prevent configuration of fdo-wfs:
> fdo-wfs depends on fdo-core (>= 3.5.0-5343); however:
> dpkg: error processing fdo-wfs (--install):
> fdo-wfs
> Selecting previously deselected package fdo-wms.
> (Reading database ... 14939 files and directories currently installed.)
> Unpacking fdo-wms (from fdo-wms_3.5.0-5343_i386.deb) ...
> dpkg: dependency problems prevent configuration of fdo-wms:
> fdo-wms depends on fdo-core (>= 3.5.0-5343); however:
> dpkg: error processing fdo-wms (--install):
> fdo-wms
> Selecting previously deselected package mapguideopensource-common.
> (Reading database ... 14962 files and directories currently installed.)
> Unpacking mapguideopensource-common (from mapguideopensource-common_2.2.0-4724_i386.deb) ...
> Setting up mapguideopensource-common (2.2.0-4724) ...
> Selecting previously deselected package mapguideopensource-server.
> (Reading database ... 15297 files and directories currently installed.)
> Unpacking mapguideopensource-server (from mapguideopensource-server_2.2.0-4724_i386.deb) ...
> Setting up mapguideopensource-server (2.2.0-4724) ...
> Selecting previously deselected package mapguideopensource-webextensions.
> (Reading database ... 15483 files and directories currently installed.)
> Unpacking mapguideopensource-webextensions (from mapguideopensource-webextensions_2.2.0-4724_i386.deb) ...
> Setting up mapguideopensource-webextensions (2.2.0-4724) ...
> Selecting previously deselected package mapguideopensource-httpd.
> (Reading database ... 16785 files and directories currently installed.)
> Unpacking mapguideopensource-httpd (from mapguideopensource-httpd_2.2.0-4724_i386.deb) ...
> Setting up mapguideopensource-httpd (2.2.0-4724) ...
> E: Couldn't find package expat
> On 1 April 2010 10:17, Trevor Wekel <trevor_wekel at otxsystems.com> wrote:
>> Just kidding.
>> I haven't had time to fully verify the "goodness" of the installation yet. On my Ubuntu 9.10 VM, the MapGuide Server started up and so did Apache/PHP. I was able to enumerate resources through the mapagent and hit the Site Admin. I figured that was good enough for one day!
>> The install script posted to http://download.osgeo.org/mapguide/testing/mginstallubuntu.sh will download all the .deb packages from the OSGeo download site and install them. The debs are dumped in /tmp/build_mapguide before they are installed.
>> wget http://download.osgeo.org/mapguide/testing/mginstallubuntu.sh
>> ./mginstallubuntu.sh
>> Please note: This is a pre-beta build and might be very broken.
>> Regards,
>> Trevor
>> mapguide-internals mailing list
>> mapguide-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
Zac Spitzer
+61 405 847 168
More information about the mapguide-internals
