[mapguide-internals] Ubuntu 9.10 is MapGuide 2.2's best friend
Zac Spitzer zac.spitzer at gmail.com
Wed Mar 31 19:51:58 EDT 2010
wow! this is great news Trevor!
ok, on a fresh 9.10 linode server I got the following errors after all
the wget-ting
some of the dependencies aren't being auto resolved
Selecting previously deselected package fdo-core.
(Reading database ... 14291 files and directories currently installed.)
Unpacking fdo-core (from fdo-core_3.5.0-5343_i386.deb) ...
dpkg: dependency problems prevent configuration of fdo-core:
 fdo-core depends on odbcinst1debian1 (>= 2.2.11-3); however:
  Package odbcinst1debian1 is not installed.
 fdo-core depends on unixodbc (>= 2.2.11-1); however:
  Package unixodbc is not installed.
dpkg: error processing fdo-core (--install):
 dependency problems - leaving unconfigured
Errors were encountered while processing:
 fdo-core
Selecting previously deselected package fdo-gdal.
(Reading database ... 14746 files and directories currently installed.)
Unpacking fdo-gdal (from fdo-gdal_3.5.0-5343_i386.deb) ...
dpkg: dependency problems prevent configuration of fdo-gdal:
 fdo-gdal depends on fdo-core (>= 3.5.0-5343); however:
  Package fdo-core is not configured yet.
dpkg: error processing fdo-gdal (--install):
 fdo-gdal
Selecting previously deselected package fdo-kingoracle.
(Reading database ... 14767 files and directories currently installed.)
Unpacking fdo-kingoracle (from fdo-kingoracle_3.5.0-5343_i386.deb) ...
Setting up fdo-kingoracle (3.5.0-5343) ...
Selecting previously deselected package fdo-ogr.
(Reading database ... 14786 files and directories currently installed.)
Unpacking fdo-ogr (from fdo-ogr_3.5.0-5343_i386.deb) ...
dpkg: dependency problems prevent configuration of fdo-ogr:
 fdo-ogr depends on fdo-core (>= 3.5.0-5343); however:
dpkg: error processing fdo-ogr (--install):
 fdo-ogr
Selecting previously deselected package fdo-postgis.
(Reading database ... 14791 files and directories currently installed.)
Unpacking fdo-postgis (from fdo-postgis_3.5.0-5343_i386.deb) ...
dpkg: dependency problems prevent configuration of fdo-postgis:
 fdo-postgis depends on fdo-core (>= 3.5.0-5343); however:
dpkg: error processing fdo-postgis (--install):
 fdo-postgis
Selecting previously deselected package fdo-rdbms.
(Reading database ... 14810 files and directories currently installed.)
Unpacking fdo-rdbms (from fdo-rdbms_3.5.0-5343_i386.deb) ...
dpkg: dependency problems prevent configuration of fdo-rdbms:
 fdo-rdbms depends on fdo-core (>= 3.5.0-5343); however:
 fdo-rdbms depends on libmysqlclient15off (>= 5.0.27-1); however:
  Package libmysqlclient15off is not installed.
 fdo-rdbms depends on odbcinst1debian1 (>= 2.2.11-3); however:
 fdo-rdbms depends on unixodbc (>= 2.2.11-1); however:
dpkg: error processing fdo-rdbms (--install):
 fdo-rdbms
Selecting previously deselected package fdo-sdf.
(Reading database ... 14892 files and directories currently installed.)
Unpacking fdo-sdf (from fdo-sdf_3.5.0-5343_i386.deb) ...
dpkg: dependency problems prevent configuration of fdo-sdf:
 fdo-sdf depends on fdo-core (>= 3.5.0-5343); however:
dpkg: error processing fdo-sdf (--install):
 fdo-sdf
Selecting previously deselected package fdo-shp.
(Reading database ... 14906 files and directories currently installed.)
Unpacking fdo-shp (from fdo-shp_3.5.0-5343_i386.deb) ...
dpkg: dependency problems prevent configuration of fdo-shp:
 fdo-shp depends on fdo-core (>= 3.5.0-5343); however:
dpkg: error processing fdo-shp (--install):
 fdo-shp
Selecting previously deselected package fdo-sqlite.
(Reading database ... 14928 files and directories currently installed.)
Unpacking fdo-sqlite (from fdo-sqlite_3.5.0-5343_i386.deb) ...
dpkg: dependency problems prevent configuration of fdo-sqlite:
 fdo-sqlite depends on fdo-core (>= 3.5.0-5343); however:
dpkg: error processing fdo-sqlite (--install):
 fdo-sqlite
Selecting previously deselected package fdo-wfs.
(Reading database ... 14933 files and directories currently installed.)
Unpacking fdo-wfs (from fdo-wfs_3.5.0-5343_i386.deb) ...
dpkg: dependency problems prevent configuration of fdo-wfs:
 fdo-wfs depends on fdo-core (>= 3.5.0-5343); however:
dpkg: error processing fdo-wfs (--install):
 fdo-wfs
Selecting previously deselected package fdo-wms.
(Reading database ... 14939 files and directories currently installed.)
Unpacking fdo-wms (from fdo-wms_3.5.0-5343_i386.deb) ...
dpkg: dependency problems prevent configuration of fdo-wms:
 fdo-wms depends on fdo-core (>= 3.5.0-5343); however:
dpkg: error processing fdo-wms (--install):
 fdo-wms
Selecting previously deselected package mapguideopensource-common.
(Reading database ... 14962 files and directories currently installed.)
Unpacking mapguideopensource-common (from
mapguideopensource-common_2.2.0-4724_i386.deb) ...
Setting up mapguideopensource-common (2.2.0-4724) ...
Selecting previously deselected package mapguideopensource-server.
(Reading database ... 15297 files and directories currently installed.)
Unpacking mapguideopensource-server (from
mapguideopensource-server_2.2.0-4724_i386.deb) ...
Setting up mapguideopensource-server (2.2.0-4724) ...
Selecting previously deselected package mapguideopensource-webextensions.
(Reading database ... 15483 files and directories currently installed.)
Unpacking mapguideopensource-webextensions (from
mapguideopensource-webextensions_2.2.0-4724_i386.deb) ...
Setting up mapguideopensource-webextensions (2.2.0-4724) ...
Selecting previously deselected package mapguideopensource-httpd.
(Reading database ... 16785 files and directories currently installed.)
Unpacking mapguideopensource-httpd (from
mapguideopensource-httpd_2.2.0-4724_i386.deb) ...
Setting up mapguideopensource-httpd (2.2.0-4724) ...
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Couldn't find package expat
On 1 April 2010 10:17, Trevor Wekel <trevor_wekel at otxsystems.com> wrote:
> Just  kidding.
> I haven't had time to fully verify the "goodness" of the installation yet.  On my Ubuntu 9.10 VM, the MapGuide Server started up and so did Apache/PHP.  I was able to enumerate resources through the mapagent and hit the Site Admin.  I figured that was good enough for one day!
> The install script posted to http://download.osgeo.org/mapguide/testing/mginstallubuntu.sh will download all the .deb packages from the OSGeo download site and install them.  The debs are dumped in /tmp/build_mapguide before they are installed.
> wget http://download.osgeo.org/mapguide/testing/mginstallubuntu.sh
> ./mginstallubuntu.sh
> Please note:  This is a pre-beta build and might be very broken.
> Regards,
> Trevor
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals mailing list
