[mapguide-internals] Re: TCPDF based plot solution
Mars Wu mars.wu at autodesk.com
Mon Mar 26 02:28:39 EDT 2012
Hi Jackie,
Thanks for the feedback.
Regarding the DPI of the plot, what the prototype showed is: PDF doesn't compress (at least we can control it) the image so that the image size fits the size of the document. That means if I stuff an 300dpi image into a A4 PDF, the image resolution will be 3508 pixel x 2480 pixel (I confirmed that by copying the image out of the PDF and paste it in MS Paint). So I guess this solution can handle the high DPI plot.
Thanks,
Mars
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Friday, March 23, 2012 4:09 PM
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] Re: TCPDF based plot solution
Having said that, the TCPDF does sound like a decent one for the short-medium term (long term, we should definitely have a dedicated SE_Renderer). All MG installations will have PHP included regardless of installation choice so no problems there.
Would this still choke on high DPI plots? I'd think so since we're still instructing the rendering service to give us an image, but we now stuff it inside a PDF correct?
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/TCPDF-based-plot-solution-tp4553444p4647804.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
