[mapguide-trac] #144: Plotting: Output georeferenced DWF
MapGuide Open Source trac_mapguide at osgeo.org
Tue Aug 7 16:04:59 EDT 2007
 Reporter:  jbirch           |         Owner:
     Type:  enhancement      |        Status:  new
 Priority:  medium           |     Milestone:
Component:  Mapping Service  |       Version:
 Severity:  major            |    Resolution:
 Keywords:                   |   External_id:
Comment (by jcarranz):
 DWFs created out MapGuide should be able to be marked up using Autodesk
 Design Review.
 When a generated DWF open in Autodesk Design Review, the map is in
 "Unknown" units. Consequently, I am unable to use the measure tools to
 produce a meaningful result. It seems clear that the actual units are in
 "page space", because when I measure across the entire width of the page,
 I get about 8.5
 At the minimum, the capability that DWF generation needs is the ability to
 embed geo-referencing information into the DWF such that:
  * the source extent can be extracted later using the DWF Toolkit API
  * Measure tools inside ADR work correctly
  * You can use Geo-specific tools like integration with GPS
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/144#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
