[mapguide-trac] #364: MgDataPropertyDefinition::Length ,GetLength() and SetLength() can be assigned to with a negative value;
MapGuide Open Source trac_mapguide at osgeo.org
Wed Dec 5 21:56:16 EST 2007
   Reporter:  jessicacao  |       Owner:  Tom Fukushima
       Type:  defect      |      Status:  new
   Priority:  medium      |   Milestone:  2.0
  Component:  General     |     Version:
   Severity:  major       |    Keywords:  MgDataPropertyDefinition::SetLength
External_id:  985014      |
 assigned to with a negative value; [[BR]]
 1. Construct an instance of MgDataPropertyDefinition using the following
 code [[BR]]
  MgDataPropertyDefinition dataPropDefinition = new
 MgDataPropertyDefinition("dataPropDefinition");[[BR]]
 2. Assigned a negative value to Length and use method GetLength to return
 the value[[BR]]
     dataPropDefinition.Length = -10; Assert.AreEqual(-10,
 dataPropDefinition.GetLength());[[BR]]
 3. Use the method SetLength to set a negative value, and use Length to
 return the value  [[BR]]
             dataPropDefinition.SetLength(-23);[[BR]]
              Assert.AreEqual(-23, dataPropDefinition.Length);[[BR]]
 Sample code: [[BR]]
             dataPropDefinition.Length = -10;[[BR]]
             Assert.AreEqual(-10, dataPropDefinition.Length);[[BR]]
             Assert.AreEqual(-10, dataPropDefinition.GetLength());[[BR]]
             Assert.AreEqual(-23 dataPropDefinition.Length);[[BR]]
             Assert.AreEqual(-23, dataPropDefinition.GetLength());[[BR]]
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/364>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
