[mapguide-trac] #142: AJAX Viewer: Numerical values not localized in status bar, measure and buffer
MapGuide Open Source trac_mapguide at osgeo.org
Thu May 17 16:41:38 EDT 2007
buffer
 Reporter:  chrisclaydon  |         Owner:  chrisclaydon
     Type:  defect        |        Status:  closed
 Priority:  medium        |     Milestone:  1.2
Component:  AJAX Viewer   |       Version:  1.2.0
 Severity:  major         |    Resolution:  fixed
 Keywords:                |   External_id:  932528
Changes (by chrisclaydon):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Fixed in 1.2.x by submission http://trac.osgeo.org/mapguide/changeset/1730
 Fixed in trunk by submission http://trac.osgeo.org/mapguide/changeset/1731
 The decimal separator and thousand separator are now defined in the
 resource file for the locale.
 The locale-specific decimal separator will be used in the status bar and
 measure display.
 The buffer command will interpret the typed-in string in the distance
 field using the locale-specific decimal and thousand separators.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/142#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
