[mapguide-trac] #143: Transforming Coordinates from MgPoint
MapGuide Open Source trac_mapguide at osgeo.org
Thu May 17 18:00:11 EDT 2007
   Reporter:  JimO     |       Owner:
       Type:  defect   |      Status:  new
   Priority:  medium   |   Milestone:
  Component:  General  |     Version:
   Severity:  major    |    Keywords:
External_id:           |
 I am able to transform coordinates on the fly from a FeatureReader,
 but not from an MgPoint. The MgPoint->Transform() returns the coordinate
 as rads and must be converted like this:
 $x = $x / M_PI * 180.0;// M_PI is the PHP constant for pi
 $y = $y / M_PI * 180.0;
 This transform into rads works from BC Albers to LL84, but does not work
 at all the other way.
 The featurereader code that works goes:
 while ($featureReader->ReadNext())
     // MgByteReader *  GetGeometry (CREFSTRING propertyName)=0
     // Gets the Geometry for the specified property.
     $byteReader = $featureReader->GetGeometry('GEOMETRY');
     // MgGeometry *  Read (MgByteReader *agf)
     // Translates an MgByteReader object into an MgGeometry object.
     $geometry = $agfReaderWriter->Read($byteReader);
     $geometry = $geometry->Transform($transform);
 The MgPoint code that works only one way and returns a coordinate as rads
 goes:
 // MgCoordinate *  CreateCoordinateXY (double x, double y)
 // Creates an MgCoordinate object with Dimension = XY
 $coord = $geometryFactory->CreateCoordinateXY((double) $_REQUEST['x'],
 (double) $_REQUEST['y']);
 // MgPoint *  CreatePoint (MgCoordinate *coordinate)
 // Creates a point from a coordinate.
 $point = $geometryFactory->CreatePoint($coord);
 // MgPoint is a subclass of MgGeometry
 $point = $point->Transform($transform);
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/143>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
