[mapguide-trac] #159: Coordinate System Overrides Not Working for ODBC or MySQL
MapGuide Open Source trac_mapguide at osgeo.org
Thu May 31 18:31:55 EDT 2007
 Reporter:  amorsell at spatialgis.com  |         Owner:  ronnielouie
     Type:  defect                   |        Status:  new
 Priority:  high                     |     Milestone:
Component:  AJAX Viewer              |       Version:  1.2.0
 Severity:  major                    |    Resolution:
 Keywords:                           |   External_id:  939549
Comment (by ronnielouie):
 Andy, I have attempted to reproduce this, but it seems work for me.  For
 clarification, here's what I am doing.  I have a table in a MySQL database
 with lat/lon columns which I define as the geometry.  I set the the
 coordsys for this to be LL84.  The layer I create for this source is
 inserted into a map, which has a Lambert Conformal Conic coordsys (WORLD-
 LM-CONIC).  When I view the map, the geometry from the MySQL layer is
 indeed transformed to the map coord sys.  Can you confirm these steps?
 What else do I need or should be doing to reproduce the behaviour you are
 seeing?
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/159#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
