[mapguide-trac] #159: Coordinate System Overrides Not Working for ODBC or MySQL
MapGuide Open Source trac_mapguide at osgeo.org
Thu May 31 19:21:01 EDT 2007
 Reporter:  amorsell at spatialgis.com  |         Owner:  ronnielouie
     Type:  defect                   |        Status:  new
 Priority:  high                     |     Milestone:
Component:  AJAX Viewer              |       Version:  1.2.0
 Severity:  major                    |    Resolution:
 Keywords:                           |   External_id:  939549
Comment (by amorsell):
 I can't get this to work for me.  I tried re-creating from scratch my ODBC
 data connection and the lat lon field geometry association, assigning
 LL84, and so on.  Then, I created a layer from it and am able to preview
 the data fine.  If I embed in a map from scratch, the map picks up the
 spatial extents correctly and everything lands where it should in LL
 space.  But, if I reference this data in a Texas State Plane, NAD83,
 Central Zone, Feet map, the data is definetely not being transformed.  I
 know for a fact that this worked fine in 1.2.0 beta 1 so I'm at a loss
 here.
 If I view just my points layer and a U.S. states layer, both in LL84,
 reference the map to a NA-LM-CONIC coordinate system, the states boundary
 transforms, but the points do not.
 Administrator shows that I'm using MapGuide Server (Version 1.2.0.1108)
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/159#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
