[mapguide-trac] #296: Table/View inconsistencies in feature joins (SQL Server 2000 - ODBC Provider)
MapGuide Open Source trac_mapguide at osgeo.org
Tue Oct 30 02:25:45 EDT 2007
Provider)
   Reporter:  jng       |       Owner:
       Type:  defect    |      Status:  new
   Priority:  high      |   Milestone:
  Component:  General   |     Version:  1.2.0
   Severity:  critical  |    Keywords:
External_id:            |
 When you join a SDF feature source with a view in SQL Server 2000, and
 create a themed layer off of it, whose style rules incorporate the joined
 values, the resulting themed layer "jumps" around when you pan/zoom around
 the map.
 However, if that view was a table, you get the correct theme applied.
 I am currently preparing a data package that illustrates the problem, and
 will attach to this ticket when done.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/296>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
