[mapguide-trac] #675: HttpServerConnection.RenderRuntimeMap() fails...
MapGuide Open Source trac_mapguide at osgeo.org
Sat Aug 23 13:18:37 EDT 2008
   Reporter:  MaksimS  |       Owner:  ksgeograf
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:
  Component:  Maestro  |     Version:  2.0.1
   Severity:  major    |    Keywords:
External_id:           |
 While trying to get rendered map using:
 Dim host As New Uri("http://server/mapguide2009/mapagent/mapagent.fcgi")
         Dim conn As New HttpServerConnection(host, "Administrator",
 "password", "en", True)
         Dim mapId As String =
 conn.GetResourceIdentifier("Folder/SubFolder/PLAN",
 ResourceTypes.MapDefinition, False)
         Dim mapDef As MapDefinition = conn.GetMapDefinition(mapId)
         Dim mapName As String = conn.GetResourceName(mapId, False)
         Dim rtMapId As String = "Session:" + conn.SessionID + "//" +
 mapName + ".Map"
         conn.CreateRuntimeMap(rtMapId, mapDef)
         Dim rtMap As RuntimeClasses.RuntimeMap =
 conn.GetRuntimeMap(rtMapId)
         Dim stream As System.IO.MemoryStream =
 conn.RenderRuntimeMap(rtMapId, 6259416.4634, 4320081.3816, 10000, 400,
 400, 75)
 Here, on conn.RenderRuntimeMap (last line) it throws following exception:
 System.Net.WebException was unhandled by user code
   Message="The request was aborted: The request was canceled."
   Source="System"
   StackTrace:
        at System.Net.ConnectStream.CloseInternal(Boolean internalCall,
 Boolean aborting)   at
 System.Net.ConnectStream.System.Net.ICloseEx.CloseEx(CloseExState
 closeState)    at System.Net.ConnectStream.Dispose(Boolean disposing)
 at System.IO.Stream.Close()    at System.IO.Stream.Dispose()    at
 OSGeo.MapGuide.MaestroAPI.HttpServerConnection.RenderRuntimeMap(String
 resourceId, Double x, Double y, Double scale, Int32 width, Int32 height,
 Int32 dpi)    at Predmet.SetMapGuide() in
 D:\DEV\Legalizacija\Predmet.aspx.vb:line 285    at Predmet.Initialize() in
 D:\DEV\Legalizacija\Predmet.aspx.vb:line 147    at
 Predmet.Page_Load(Object sender, EventArgs e) in
 D:\DEV\Legalizacija\Predmet.aspx.vb:line 44    at
 System.Web.UI.Control.OnLoad(EventArgs e)    at
 System.Web.UI.Control.LoadRecursive()    at
 System.Web.UI.Page.ProcessRequestMain(Boolean
 includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
   InnerException: System.IO.IOException
        Message="Cannot close stream until all bytes are written."
        Source="System"
        StackTrace:
 internalCall, Boolean aborting)
        InnerException:
 ...instead of returning rendered Stream.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/675>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
