[mapguide-trac] #675: HttpServerConnection.RenderRuntimeMap() fails...
MapGuide Open Source trac_mapguide at osgeo.org
Sun Aug 24 18:26:01 EDT 2008
 Reporter:  MaksimS  |         Owner:  ksgeograf
     Type:  defect   |        Status:  new
 Priority:  low      |     Milestone:
Component:  Maestro  |       Version:
 Severity:  major    |    Resolution:
 Keywords:           |   External_id:
Changes (by ksgeograf):
  * version:  2.0.1 =>
Comment:
 This is very strange, because I use the WebClient.DownloadData call, so
 there is really nothing to change.
 Are you certain that your parameters are correct?
 If you use the source code for Maestro, what url does it send?
 (You can use fiddler to get the URL, if you dislike using the source
 code).
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/675#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
