[mapguide-trac] #649: FeatureService.UpdateFeatures doesn't log errors and reports them as succesful
MapGuide Open Source trac_mapguide at osgeo.org
Wed Dec 3 18:44:07 EST 2008
succesful
 Reporter:  zspitzer         |         Owner:
     Type:  defect           |        Status:  new
 Priority:  medium           |     Milestone:
Component:  Feature Service  |       Version:  2.0.2
 Severity:  critical         |    Resolution:
 Keywords:                   |   External_id:
Changes (by zspitzer):
  * version:  2.0.1 => 2.0.2
  * summary:  FeatureService.UpdateFeatures doesn't log or throw errors =>
Comment:
 Ok, test case attached, it uses the a feature source from the Sheboygan
 Samples. It will fail to make any changes, due to the SDF being marked as
 READ ONLY and the FeatureClass name is wrong ( should be Rail, is Rail3)
 Simply run the script, tweaking the user/pass if required.
 '''Current Behaviour:''' An error is returned in the result which must be
 manually inspected and the access.log reports the UpdateFeatures operation
 as being Successful.
 UpdateFeatures.1.0.0:3(Library://Samples/Sheboygan/Data/Rail.FeatureSource,MgFeatureCommandCollection,false,)
 Success
 '''Expected Behaviour:''' An error should be thrown (to be caught), the
 UpdateFeatures accesslog entry should be marked as Failure
 Failure
 In addition the error message should be logged to error.log
 An exception occurred in FDO component. Item 'Rail3' not found in
 collection
 Exception occurred in method MgServerUpdateFeatures.UpdateFeatures at line
 97 in
 file
 d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.13\mgdev\server
 \src\services\feature\ServerUpdateFeatures.cpp
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/649#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
