[mapguide-trac] #782: Flexible web layout not working on Linux installation
MapGuide Open Source trac_mapguide at osgeo.org
Wed Dec 3 18:54:17 EST 2008
 Reporter:  ronnielouie  |         Owner:  ronnielouie
     Type:  defect       |        Status:  closed
 Priority:  high         |     Milestone:
Component:  Fusion       |       Version:  2.0.1
 Severity:  critical     |    Resolution:  fixed
 Keywords:               |   External_id:  1170613
Changes (by ronnielouie):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Viewing a flexibe web layout was causing segmentation fault in Apache, and
 as a result, the map is not displayed.  This is caused by the retrieval of
 the ApplicationDefinition in json format.  An investigation of the stack
 trace identified that that the methods to output json as failing due to
 unchecked null values.  The solution is to add a check for null before
 attempting to use the parameter.
 After the fix, viewing flexible layout on Internet Explorer and Firefox is
 successfull.  Also peformed some quick pan, zooom and selection of
 features.
 http://trac.osgeo.org/mapguide/changeset/3495
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/782#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
