[mapguide-trac] #803: Maestro API: Default settings for resource classes
MapGuide Open Source trac_mapguide at osgeo.org
Thu Dec 18 21:24:58 EST 2008
   Reporter:  jng          |       Owner:  ksgeograf
       Type:  enhancement  |      Status:  new
   Priority:  low          |   Milestone:
  Component:  Maestro      |     Version:  2.0.1
   Severity:  trivial      |    Keywords:
External_id:               |
 It would be nice if resource types are initialized with default settings.
 Since these classes are generated off the xsd schemas (correct?), there is
 a lot of boilerplate code required to explicitly set all the required
 elements for a given resource.
 For example:
 Layer Definition:
   - Create a default line/point/polygon style
 Web Layout:
   - Create a default command list.
   - Create a default toolbar/context menu/task pane bar configuration.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/803>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
