[mapguide-trac] #803: Maestro API: Default settings for resource classes
MapGuide Open Source trac_mapguide at osgeo.org
Fri Dec 19 05:17:26 EST 2008
 Reporter:  jng          |         Owner:  ksgeograf
     Type:  enhancement  |        Status:  assigned
 Priority:  low          |     Milestone:
Component:  Maestro      |       Version:
 Severity:  trivial      |    Resolution:
 Keywords:               |   External_id:
Changes (by ksgeograf):
  * status:  new => assigned
  * version:  2.0.1 =>
Comment:
 The easiest way to accomplish this is to use the "DeserializeObject"
 method, and give it a file stream as input. There are some templates in
 the "Templates" folder.
 A simple solution would be to embed these in the MaestroAPI.dll, and
 create methods to generate objects from them. Does that seem like a
 resonable solution?
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/803#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
