[mapguide-trac] #599: Set scale ranges by group?
MapGuide Open Source trac_mapguide at osgeo.org
Mon Jun 9 16:11:36 EDT 2008
 Reporter:  andrewd      |         Owner:  ksgeograf
     Type:  enhancement  |        Status:  new
 Priority:  low          |     Milestone:
Component:  Maestro      |       Version:  2.0.1
 Severity:  trivial      |    Resolution:
 Keywords:               |   External_id:
Comment (by ksgeograf):
 Are you thinking of selecting a group in the map editor, and setting
 scales for all layers in that group?
 If so, yes, it is possible.
 But it might have some undesireable sideeffects, as the layers may be used
 elsewhere. Layers may also have more than one scalerange.
 If such a feature was implemented, should it warn users if the layer is
 part of another map? Or even another group in the map?
 How do you propose to handle cases where the layer has multiple
 scaleranges? (Ignore, Set only first, Delete all but first, Nothing, Force
 all ranges into the desired range, Something else?)
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/599#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
