[mapguide-trac] #599: Set scale ranges by group?
MapGuide Open Source trac_mapguide at osgeo.org
Mon Jun 9 18:33:23 EDT 2008
 Reporter:  andrewd      |         Owner:  ksgeograf
     Type:  enhancement  |        Status:  new
 Priority:  low          |     Milestone:
Component:  Maestro      |       Version:  2.0.1
 Severity:  trivial      |    Resolution:
 Keywords:               |   External_id:
Comment (by andrewd):
 Yes, I was thinking in the map editor - setting scales for all layers in
 that group. I know it could have some side effects, but if you gave the
 user an option like you suggest, I think it would still be useful. It
 would certainly have been useful for me today, anyway. Ultimately, it
 would be nicer if you could just set a group to handle the scales, but
 that's a mapguide issue. This would basically be a workaround until they
 implement that (if ever).
 The safest thing would be to alert the user if the layers are in use
 elsewhere. Basically, have a max and min field for each group, and when
 you set that, it adds that scale range to each layer in the group. I
 suppose editing would be tricky. Like, what if you set the min to 1 and
 max to 10000, but then wanted to change it to min 1 max 5000? Maybe the
 simplest thing is to only have it work for layers with a single scale
 range? That way it could just overwrite any existing scale range...Just
 thinking out loud here....
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/599#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
