[mapguide-trac] #599: Set scale ranges by group?
MapGuide Open Source trac_mapguide at osgeo.org
Tue Jun 10 06:39:06 EDT 2008
 Reporter:  andrewd      |         Owner:  ksgeograf
     Type:  enhancement  |        Status:  new
 Priority:  low          |     Milestone:
Component:  Maestro      |       Version:  2.0.1
 Severity:  trivial      |    Resolution:
 Keywords:               |   External_id:
Comment (by ksgeograf):
 I think it could work if the user was given an option to do the fixup in-
 place or copy the layers to a chosen folder.
 As for the multiple scales, I agree that MapGuide should eventually be
 able to handle it. In the meantime, I propose a system like this:
 Layer has scale ranges [0:500] and [501:1000].
 User selects that the group should only be visible in [200:700].
 First layer scale range is truncated to [200:500], second becomes
 [501:700].
 But I don't know what to do if the layer that has scale range
 [1000:infinity]?
 Perhaps just remove the range?
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/599#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
