[mapguide-trac] #599: Set scale ranges by group?
MapGuide Open Source trac_mapguide at osgeo.org
Tue Jun 10 08:14:02 EDT 2008
 Reporter:  andrewd      |         Owner:  ksgeograf
     Type:  enhancement  |        Status:  new
 Priority:  low          |     Milestone:
Component:  Maestro      |       Version:  2.0.1
 Severity:  trivial      |    Resolution:
 Keywords:               |   External_id:
Comment (by andrewd):
 I like your proposed method for the 0:500, 501:1000 case, for sure. If
 someone has a single scale range of 1000:infinity, and they tried to set
 the scale to something like 200:500, then you'd just have to replace the
 1000:infinity with the new one - but you could ask the user what to do,
 for sure.
 So, if you had a case like 0:999, 1000:infinity and a desired 500:2000,
 you'd have to do something like 0:500, 501:2000....so long as you ask the
 user what to do in cases like that, I think it's a good method.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/599#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
