[mapguide-trac] #600: WMS - coordinate system overriding fails
MapGuide Open Source trac_mapguide at osgeo.org
Tue Jun 10 08:44:53 EDT 2008
   Reporter:  gBecker        |       Owner:
       Type:  defect         |      Status:  new
   Priority:  high           |   Milestone:
  Component:  WMS Interface  |     Version:  2.0.1
   Severity:  critical       |    Keywords:
External_id:                 |
 In MGOS 2.0.1 coordinate system overriding for WMS fails. No WMS layers
 showing up anymore. With version 1.2 there was no problem. I've tested it
 with Windows Vista and Windows Server 2003.
 I recognized some logging entries in Error.log. It says the coordinate
 system of the layer is not the same as the one for the map. It seems that
 MapGuide doesn't look up the SpatialContext-Node of my Config.xml. Maybe
 doesn't look up the configuration file at all.
 By the way, the same configuration in MapGuide Enterprise 2009 works fine.
 Gunter
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/600>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
