[mapguide-trac] #601: MapGuide Maestro: image tiling in composite mode is not working
MapGuide Open Source trac_mapguide at osgeo.org
Fri Jun 13 09:55:15 EDT 2008
 Reporter:  dumas65  |         Owner:  ksgeograf
     Type:  defect   |        Status:  new
 Priority:  low      |     Milestone:
Component:  Maestro  |       Version:  2.0.1
 Severity:  trivial  |    Resolution:
 Keywords:           |   External_id:
Comment (by ksgeograf):
 I have now tried loading you ECW file.
 I placed it in a folder (C:\ecw2) and created a featuresource with just
 that one file.
 Then I created a layer, and referenced the featuresource.
 Then I created a map with the layer, and used the "Set extent to selected
 layer".
 I got these values: 585000, 6010000, 590000, 6015000.
 I then tried the exact same procedure, but instead of using a single file,
 I added it as a composite. The resulting config file is attached. The
 result was the same.
 I can see both layers in a clean map/weblayout. I suspect that you are
 missing either the gdal_ecw plugin or the libecwj2.dll. What happens when
 you try to run the server in interactive mode? (See this page:
 http://trac.osgeo.org/fdo/wiki/FdoGdalNotes#DebuggingRastersinMapGuide)
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/601#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
