[mapguide-trac] #601: MapGuide Maestro: image tiling in composite mode is not working
MapGuide Open Source trac_mapguide at osgeo.org
Fri Jun 13 09:56:55 EDT 2008
 Reporter:  dumas65  |         Owner:  ksgeograf
     Type:  defect   |        Status:  new
 Priority:  low      |     Milestone:
Component:  Maestro  |       Version:  2.0.1
 Severity:  trivial  |    Resolution:
 Keywords:           |   External_id:
Comment (by ksgeograf):
 If you want to add the layer to a map with existing layers, the feature
 source MUST have a coordinate system override with the maps EXACT
 coordinate system.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/601#comment:5>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
