[mapguide-trac] #601: MapGuide Maestro: image tiling in composite mode is not working
MapGuide Open Source trac_mapguide at osgeo.org
Fri Jun 13 11:05:20 EDT 2008
 Reporter:  dumas65  |         Owner:  ksgeograf
     Type:  defect   |        Status:  new
 Priority:  low      |     Milestone:
Component:  Maestro  |       Version:  2.0.1
 Severity:  trivial  |    Resolution:
 Keywords:           |   External_id:
Comment (by dumas65):
 OK, I was searching for gdal_ecw and libecwj2.dll, but no results. Maybe
 this is the case. During installations I was following instruction written
 in
 http://mapguide.osgeo.org/sites/mapguide.osgeo.org/files/GettingStarted.pdf
 installing MapGuide Server and MapGuide Web Server Extensions on winXP. I
 changed parameter from console to install both server and extensiontions
 to drive F:
 I tried to play around with mapguide in virtual machine running win2000
 using default paths for server and extensions, but eventually had same
 problems.
 There is some of output from interactive mode:
 GDAL: GDALOpen(E:\Data\ORT10LT-2006\2//2749.aux) succeeds as HFA.
 GDAL: GDALClose(E:\Data\ORT10LT-2006\2//2748.tif)
 GDAL: GDALOpen(E:\Data\ORT10LT-2006\2//2749.tif) succeeds as GTiff.
 GDAL: GDALClose(E:\Data\ORT10LT-2006\2//2748.aux)
 GDAL: GDALOpen(E:\Data\ORT10LT-2006\2//2750.aux) succeeds as HFA.
 GDAL: GDALClose(E:\Data\ORT10LT-2006\2//2749.tif)
 GDAL: GDALOpen(E:\Data\ORT10LT-2006\2//2750.tif) succeeds as GTiff.
 GDAL: GDALClose(E:\Data\ORT10LT-2006\2//2749.aux)
 Looks like world files *.tfw are not detected.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/601#comment:6>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
