[mapguide-trac] #565: Add support for editing Xml config files on resources
MapGuide Open Source trac_mapguide at osgeo.org
Fri Jun 13 13:36:09 EDT 2008
 Reporter:  ksgeograf    |         Owner:  ksgeograf
     Type:  enhancement  |        Status:  assigned
 Priority:  medium       |     Milestone:
Component:  Maestro      |       Version:
 Severity:  major        |    Resolution:
 Keywords:               |   External_id:
Comment (by ksgeograf):
 That depends on what you mean. CS overrides is in the feature Xml and
 supported. I'm not sure what can be done with WMS besides coordinate
 system override.
 This issue is here to remind me to implement a feature that allows a user
 to open the config file in the internal editor, edit it, and save it. This
 will ease the current method where the file must be downloaded to disk,
 edited externally and then uploaded again.
 If you mean something else, please do create a new issue.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/565#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
