[mapguide-trac] #606: Maestro: Consider adding a "Repointer" function
MapGuide Open Source trac_mapguide at osgeo.org
Fri Jun 13 13:40:14 EDT 2008
   Reporter:  jbirch       |       Owner:  ksgeograf
       Type:  enhancement  |      Status:  new
   Priority:  low          |   Milestone:
  Component:  Maestro      |     Version:
   Severity:  trivial      |    Keywords:
External_id:               |
 It would be useful to be able to click on a Layer and say "Point all maps
 that reference this layer to this other layer instead", and the same for
 MapDefinitions (and WebLayouts/ApplicationDefinitions).
 Similar option would be cool for data connections as well, but much more
 complex because of potential for mis-matched schemas.  To implement this
 you would also need to have a validity checker for layer definitions,
 allowing the user to list layers with invalid definitions, and visually
 see which properties are invalid when the layer is open.  MapGuide Studio
 (at least up to 2008?) just resets the layer definition when there are
 different schemas regardless of whether it would invalidate the layer
 definition, but this is not a desirable behaviour.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/606>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
