[mapguide-trac] #606: Maestro: Consider adding a "Repointer" function
MapGuide Open Source trac_mapguide at osgeo.org
Fri Jun 13 14:01:34 EDT 2008
 Reporter:  jbirch       |         Owner:  ksgeograf
     Type:  enhancement  |        Status:  assigned
 Priority:  low          |     Milestone:
Component:  Maestro      |       Version:
 Severity:  trivial      |    Resolution:
 Keywords:               |   External_id:
Changes (by ksgeograf):
  * status:  new => assigned
Comment:
 Yes, that would be a very nice feature. Currently Maestro does nothing if
 you change the schema, even if the layer does not render anymore. When
 #560 is implemented, This should not be a problem. In any case, I think it
 is better to allow the user fix the layer, rather than requiring a full
 reconstruction. Once a validation/warning system is in place, that will be
 optimal.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/606#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
