[mapguide-trac] #579: add "load procedures"
MapGuide Open Source trac_mapguide at osgeo.org
Fri Jun 13 14:16:16 EDT 2008
 Reporter:  andrewd      |         Owner:  ksgeograf
     Type:  enhancement  |        Status:  assigned
 Priority:  medium       |     Milestone:
Component:  Maestro      |       Version:
 Severity:  minor        |    Resolution:
 Keywords:               |   External_id:
Comment (by ksgeograf):
 It is always possible to upload files using the generic featuresource
 editor. Some of the editors (SDF, filebased-OGR, ODBC) also has an option
 to upload files, automatically setting the path correctly.
 You can chose "Internal file (managed)" and upload SDF, SHP, TAB, etc.
 files. You can even upload a number of SHP files, and use the entire
 folder as a single datasource with multiple schemas (pending inclusion of
 a patch in OGR, should be in next version).
 I did not add that feature to raster provider, because I find it ackward
 to have so large files in the server, and the upload itself will be huge,
 and probably hit numerous timeout problems.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/579#comment:9>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
