[mapguide-trac] #607: Maestro: DBXML exception on saving layer with polygon stroke specified
MapGuide Open Source trac_mapguide at osgeo.org
Fri Jun 13 17:29:15 EDT 2008
   Reporter:  jbirch   |       Owner:  ksgeograf
       Type:  defect   |      Status:  new
   Priority:  medium   |   Milestone:
  Component:  Maestro  |     Version:
   Severity:  major    |    Keywords:
External_id:           |
 When I try to add a stroke styling to a polygon layer, I get an exception
 on saving, indicating that Unit, or Color, or other elements are not valid
 for content model.
 Noticed that the default LayerDefinition is 1.1.0, but manually changing
 header to 1.2.0 doesn't seem to help.
 <?xml version="1.0" encoding="utf-8"?>
 <LayerDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
 xmlns:xsd="http://www.w3.org/2001/XMLSchema"
 xsi:noNamespaceSchemaLocation="LayerDefinition-1.1.0.xsd" version="1.1.0">
   <VectorLayerDefinition>
 <ResourceId>Library://Nanaimo/Shared/Data/SDF/Carto/CityFill.FeatureSource</ResourceId>
     <FeatureName>Default:CityFill</FeatureName>
     <FeatureNameType>FeatureClass</FeatureNameType>
     <Filter />
     <Geometry>Geometry</Geometry>
     <Url />
     <ToolTip />
     <VectorScaleRange>
       <AreaTypeStyle>
         <AreaRule>
           <LegendLabel />
           <AreaSymbolization2D>
             <Fill>
               <FillPattern>Solid</FillPattern>
               <ForegroundColor>ffffffff</ForegroundColor>
               <BackgroundColor>ffffffff</BackgroundColor>
             </Fill>
             <Stroke>
               <LineStyle>Solid</LineStyle>
               <Color>000000</Color>
               <Unit>Millimeters</Unit>
               <SizeContext>MappingUnits</SizeContext>
             </Stroke>
           </AreaSymbolization2D>
         </AreaRule>
       </AreaTypeStyle>
     </VectorScaleRange>
   </VectorLayerDefinition>
 </LayerDefinition>
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/607>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
