[mapguide-trac] #592: Layer preview
MapGuide Open Source trac_mapguide at osgeo.org
Sat Jun 14 03:29:23 EDT 2008
#592: Layer preview
 Reporter:  andrewd      |         Owner:  ksgeograf
     Type:  enhancement  |        Status:  closed
 Priority:  medium       |     Milestone:
Component:  Maestro      |       Version:
 Severity:  minor        |    Resolution:  fixed
 Keywords:               |   External_id:
Changes (by ksgeograf):
  * status:  reopened => closed
  * resolution:  => fixed
Comment:
 Yes, there is an error related to reading the fusion template. Just delete
 the file "Preview layout.ApplicationDefinition" and it should work.
 The preview reads out the extent that the datasource reports to have, and
 zooms to that. I can see that might be a bit confusing, because you have
 to zoom in to actually see something.
 Can you open up the scale problem/point problem as a new issue?
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/592#comment:13>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
